How Many RPM's
IHCM
06-28-2007 04:56:20
Hey guys, I have been offered a motor for a Farmall M. It has a 4.38 bore, and a 7.25 stroke. My question is, he has welded conneting rods in the motor and I am wondering how many rpm's a guy can run those without fear that they will break?
Thanks for any help.
buickanddeere
06-29-2007 07:37:47
 Re: How Many RPM's in reply to IHCM, 06-28-2007 04:56:20
Centrifical force increases four times when the engine speed is doubled. The force increases nine times when the engine speed is tripled. Centrifical force will also be four times more if the stroke is doubled. So lets see, if you spin it at 3300rpms the centrifical force on the bottom end with be 7.63 times that of a stock engine at stock rpms. How lucky do you feel and for how long do you feel lucky? Has the valve train been upgraded to prevent whacking valves into pistons?
IHCM
06-29-2007 10:31:56
 Re: How Many RPM's in reply to buickanddeere, 06-29-2007 07:37:47
He is only running about 2100 rpms now. I was just wondering if a guy couls go to around 2600 without much wory, or is it just going to be asking for troubles?
buickanddeere
06-30-2007 08:59:47
 Re: How Many RPM's in reply to IHCM, 06-29-2007 10:31:56
2600rpms will be 4.7 times the stress.2100rpms is 3.01 times the stress. This can vary should the rods or pistons be heavier or lighter than stock. The crank is certainly heavier than stock after stroking. The stress on the flywheel & clutch increases with the square of the rpms as well.
ChadS
07-02-2007 07:04:59
 Re: How Many RPM's in reply to buickanddeere, 06-30-2007 08:59:47
Thats too fast. The piston speed will be so fast, you may as well had a stock motor and spin it at 5000 + rpm. Something will come apart. Those motors can make good power dialed in for lower rpms, Intended maybe for up to 10% over rpm range.Ive seen em run higher, but they dont pull em anymore for some reason. Chad
AW Puller
06-28-2007 10:42:44
I think it has a lot to do with who welded them. I have seen some really nice welded rods that I wouldn't be scared of at all and I have seen some that weren't even straight and was suprised the engine even ran.
