Rules
No power
06-25-2007 07:50:21
Every place that I go to the rules seem to vary alittle. What are the rules for stock classes. Can you run a header and pressed steel wheels. If the tractor didn't orignally have them. Do all parts such as hydrolic pumps need to be in place or can they be taken off. Can you run side sheilds. I know that you can't have cut tires. The block has to be original those are the only 2 that I know for sure.
jpl
06-25-2007 10:29:59
 Re: Rules in reply to No power, 06-25-2007 07:50:21
go to www.usapuller.com look under rules this covers most pulls. hope this helps you. also see the results of pulls see how your tractor does.
