different size wheels
jpl
06-24-2007 09:00:42
I put 2 other wheels and tires on my tractor and one is two inches higher, will this make it pull to one side. one is firestone and other is goodyear, 18/34"s only pulling 3.5 mph class. maybe 5 mph class also. 6000, 6500 class, thanks for all feedback.
jpl
06-24-2007 22:23:20
 Re: different size wheels in reply to jpl, 06-24-2007 09:00:42
i just ask a simple question, now i;m cheap, if i;m spinning the tires i must be on someone elses tractor not mine. at the slow speed i run i;ll let you all know how it does at next pull after all i pull for the fun of it anyway, . i run stock tires against cut tires and sometimes beat them so i;m satisfied. thanks for all replies.
MJF
06-25-2007 18:27:49
 Re: different size wheels in reply to jpl, 06-24-2007 22:23:20
Hey I pulled mismatched 15.5's on my M for years. One was a considerably better pulling tire than the other. I knew this from pulling it, so I just weighted the tractor to match the tires. Won many ribbons with it that way.
Don-Wi
06-24-2007 21:25:06
For an old farm tractor or duals, I'd say mis-matched tires are fine, but on a puller I'd think a pair of mis-matched tires could really play havoc on your success.
Donovan from Wisconsin
alliecat
06-24-2007 18:01:53
i have 2 18.4 x 34 co-op tires road worn good for pulling will take $100 for the pair you pick up i'm in north central tennesse
jpl
06-24-2007 22:48:09
 Re: different size wheels in reply to alliecat, 06-24-2007 18:01:53
hey alliecat, i;ll see what the old girl will do first, i;m a over the road driver, if need tires i can stop going thru your state and throw them in the trailer, i;m in ohio but go texas and fla alot. thank you.
smdv806
06-24-2007 12:56:49
Don"t be cheap, match your wheels and tires. The taller the tire the faster it will go. When one is taller than the other the wheels wont spin the same speed. To your rearend it is just like turning or hitting a slick spot you WILL spin out.
