pulling the 1206
Joe1206
06-21-2007 18:55:41
Was wondering what gear I should pull in. Thing is the torque is weak and I dont want to rely on it. It was sitting on 140 hp. I turned it up all the way now. I havent checked the hp. How much do you guys think its pushing? Anyways just want advice on what gear to pull in. BTW im not sure what it weighs. No fluid. 4 sets of wheel weight. axel mount hubs on. Thanks for any info.
Farmallstroker
06-21-2007 19:42:17
 Re: pulling the 1206 in reply to Joe1206, 06-21-2007 18:55:41
I have a 856 I pull every now and then and I run 5th in the 10500 and under and 4th anything over 10500. Should be about right I run 130hp with no turbo and the pump isnt turned all the way up with 18.4-38.
Someday
06-24-2007 16:05:49
 Re: pulling the 1206 in reply to Farmallstroker, 06-21-2007 19:42:17
In a 856 Where do you find a 5th Gear?? I pull a 856 no turbo 110hp If you could give me your number i would like to talk to you on how you can get 130hp stock THANK YOU
