466 deere safe rpm
weeze
06-21-2007 04:34:00
i just bought a 4010 with a stock 466 engine the club rules allow 4000rpms what is a safe rpm for a stock engine to be reliable? i need to know before i buy the pump and injectors. thanks
sflem849
06-22-2007 20:28:04
 Re: 466 deere safe rpm in reply to weeze, 06-21-2007 04:34:00
Our 466 class only requires a steel flywheel if over 2800, but our max is 3500.
Personally after the two saftey measures I would turn 4000. Build, Pull, Break, Repeat as Necessary!
papuller
06-21-2007 04:55:07
Please, do us all a favor and buy a steel flywheel and pulling clutch before you turn up the RPM's.
Jeremy7810
06-27-2007 19:17:47
 Re: 466 deere safe rpm in reply to papuller, 06-21-2007 04:55:07
I have steel flywheel and clutch and injectors u need call me @ 812-236-4419
