Motors
No power
06-20-2007 08:49:17
Are 450 motors and super M motors inerchangable.
MJF
06-20-2007 18:31:38
 Re: Motors in reply to No power, 06-20-2007 08:49:17
A 450 block will bolt right in a SM if thats what your asking
champspa
06-20-2007 13:52:09
no there is a lot more meat in the piston area in a 281 block , in other words you can bore a 281 bigger
Pulls Farmalls
06-20-2007 10:50:09
The casting no isthe same.Only difference in the block is date code and ci casting marks.You can take every piece out of one block and put it in the other one .heads if original are different.You have to match the pistons to the sleeves if 4 inch.Be advised 450 pistons WILL hit an 8060 head.I have done it but it takes a lot of grinding on both.
