weights
Steve2007
06-19-2007 10:19:32
In those who pull a lot does 500lbs of water in your tires help more than 500 on back for tractor
steve
Steve2007
06-19-2007 19:49:18
 Re: weights in reply to Steve2007, 06-19-2007 10:19:32
My tractor squats good with 8lbs psi I was just thinking alot of the tractors around my area that does the best is when wieght is put on as far back of tractor.Im thinking if i had that 500lbs took out of my 14.8s and hang on back if that would work better.Having traction problems in 7200 class with new tires.7700 and 8200 no traction problems
BlakeG
06-19-2007 14:18:47
Water in your tires is the worst way of adding weight, it doesnt let your tires squat, so they dont get a good bite!
No Water
06-19-2007 19:59:20
 Re: weights in reply to BlakeG, 06-19-2007 14:18:47
Plus you can't move it if you need to! You get no leverage only a heavier tractor.
