To much trouble?
jdjack
06-13-2007 18:38:56
I have a JD A 1944 hand start. Started to pull with it. It is bored .125 over. had head shaved about .70. Ran for a few years and didn't seem to have enough power. Found out that valves were not setting good. Took head back off and had valve seats ground again, correctly. And alittle porting and polishing work done around valves.
Put on dyno runs good and has about 35 hp.
Sat over winter and start this spring and guess what, coolant in cylinder and oil. I know that I have coolant leaking into #1 cylinder. Don't know if it's block or head or headgasket.
Just woundering if this is normal to have this much and kind of troubles.
Thinking about draining coolant and just running water for 2 pulls and then tear it down. just getting sick of always working on it.
mlpankey
06-15-2007 14:51:21
 Re: To much trouble? in reply to jdjack, 06-13-2007 18:38:56
when bad luck sets in its hard to shake. i would try silicon glass in the radiator with plain water if its a crack or head gasket it will seal it .if it doesnt stop it then its a hole .belzona will fix holes you can look at www.belzona . com . ill warn you its pricey at 194.00 for 1 kg.
bigmotors
06-13-2007 23:26:59
Yes-you have problems. You should have around 45 to 50 hp. and still be able to use it around the farm. (with good gas) Find another head and just stick it on. See if this helps. If it is the block, spend the time and fill in the other side of the piston where the extra spark plug gap groove is. Make sure the other side has a clean groove for the spark plug hole. Don't get crazy with port and polishing with this set up. Just clean things up. Try a #71 or #51 carb. A unstyle "A" with a 6.500 crank with .125 over runs around 38 to 40 hp. Try to find a heisler head.
Good Luck!
turbos10
06-13-2007 21:09:13
Your projects sound like most of mine. Lucky for me I like building things as much as the finished product. However, I have one three year project sitting due to problems like this...I just needed a break. That is actually why I got into pulling; drag racing was too much work and money.
