Farmall M Turbo
FarmallMman
06-13-2007 10:49:45
I have heard of Farmall M's with a turbo but will it take two turbos.
turbos10
06-13-2007 18:16:14
 Re: Farmall M Turbo in reply to FarmallMman, 06-13-2007 10:49:45
Are you refering to a compound setup? It was my experience that with as little as 15psi at 2500 RPM I could not get the power to the ground without adding a bunch of weight, so you dont need a ton of boost on a setup like that. I built mine for RPM so I could get the speed and HP I need to run fast down the track.
If I were you, I would try a single and go from there. I dont think you will need anything else unless you are going to try to pull at 9-10,000 lbs. In that case, you better make plans for the transmission as well.
LONESTAR
06-13-2007 12:47:19
all i can say is----my motto---BUILD, BREAK, REPEAT.
