spare parts
kendak
06-13-2007 05:42:01
What do I need to put on spare parts like heads, crankshaft, pistons ,rods , blocks to keep them from rusting ? most of this is kept inside but I don't have room for everything...also what about parts tractors that are outside with good parts...here in the MS. things rust pretty quick in or outside....paint ,grease ,oil ,what ??thanks ..Kent
Mike Aylward
06-13-2007 11:58:24
 Re: spare parts in reply to kendak, 06-13-2007 05:42:01
Kent, I have had very good luck with plow paint from most any farm supply store. You can use it as is and when it dries it will protect about any non-painted part. When you are ready to use the part simply wash off the plow paint and install. Plow paint will dry which makes it easier to move the parts around. Oily products will protect, too, but they are "ornery" to deal with in this application. Mike
kendak
06-14-2007 12:08:39
 Re: spare parts in reply to Mike Aylward, 06-13-2007 11:58:24
Thanks for the reply..as a farmer I never heard of [ plow paint ]but I'm sure I can find some on the internet..in the MS. delta plows have never been used but in rare cases...its either chisel plow or disk...Kent
