Slobbering smoking 560
LittleMackinawFarmall
06-09-2007 19:52:50
Okay awhile back I asked about my 560 slobbering oil out of the exhaust at idle...well I think it is dong it as it second job more than just at idle....say after 1 hour on a 10" auger oil is down the sides of the hood. Then today we had a tractor ride then pull ended up with a rag around the bottom of the muffler to keep oil off everything and it is blowing a little whiser of white smoke and alot at the pull and did LOUSY... and suggestions this is my first 282 not used to antique deisels not sure even where to start THANKS!
Jim Johnson
06-10-2007 11:39:39
 Re: Slobbering smoking 560 in reply to LittleMackinawFarmall, 06-09-2007 19:52:50
I think Greg is right. Use some Lucas Upper Cylinder Lubricant fuel conditioner also in a pretty liberal quantity at first.
I think that should be all you need to do because this is fairly common in these tractors when not used very hard.
Jim
Greg_Ky
06-10-2007 09:43:32
Sounds like typical slobbering from not being used. Diesels do not like to be babied, it sounds like you have fueled it down from not working it hard enough. Change the oil and WORK IT AND WORK IT HARD for four to five hours and you should be OK.HTH
ChadS
06-10-2007 07:52:30
This can get costly. Could be just a headgasket, bad valves and guides. Could be the pump is going south, and or the injectors. Pistons and rings and sleeves. Pull the injectors and run a compression test with a high pressure guage. If they are reading within 5-10 psi of each other, Id say the engine is possibly ok and start looking at the pump and injectors. If it was me, Id pull the head and know for sure, the sheetmetal is harder to remove than the head is,, LOL! Headgasket sets arent too bad on cost, and if you find nothing wrong, at least you know that that area is in good shape, and wont go out later. Chad
