looking for jd a pullin info
nyjdguy
06-08-2007 10:53:49
I have a 48 A. I'm running 14.9-38 armstrongs, power block with g pistons and i think there's 175 th's of the head. What i'm looking for is any info you guys can give me making this tractor pull harder i neeed more power. Also ideas on weight brackets thanks ahead of time.
RWWisehart
06-09-2007 10:08:36
 Re: looking for jd a pullin info in reply to nyjdguy, 06-08-2007 10:53:49
Stroke it, that is where you get your power. I have a 1936 A JD bored and stroked, will out pull the M Farmall and Olivers in 2nd gear 4500 5000 and 5500. Got to love it, to see those guys with there chin on the ground.
kent dakin
06-11-2007 08:33:15
 Re: looking for jd a pullin info in reply to RWWisehart, 06-09-2007 10:08:36
Hey ! Wisehart how about some details on your setup as I am building a 37 model to do the same thing !!..thanks Kent
The Dukester
06-09-2007 06:25:26
Geesh, you oughta have 50 horse or better with the engine set-up you got. Don't try to pull with the high speed classes...your A doesn't have 100 plus horses like some of the Ollies, big Minnies and long stroked Farmalls have. Stay with the 5500-6500 3-4 mph stuff, that's where your tractor is competitive. Don't get "sucked in" to tryin' to pull with the high revvin, multi-cylinder crowd...it'll break you heart...and maybe your tractor too.
nyjdguy
06-09-2007 07:43:39
 Re: looking for jd a pullin info in reply to The Dukester, 06-09-2007 06:25:26
thanks guys
phil2
06-08-2007 19:14:16
I don't think you're going to need more power if it is tuned nicely - my guess is that, at 5500 pounds, it will spin out even with the throttle backed down and the front wheels lifted. About 6 or 7 psi should work well in the 14.9 tires.
deereabhm
06-08-2007 21:25:22
 Re: looking for jd a pullin info in reply to phil2, 06-08-2007 19:14:16
Howabout 8 MPH?
MJF
06-08-2007 11:33:55
What weight do you pull
nyjdguy
06-08-2007 12:18:40
 Re: looking for jd a pullin info in reply to MJF, 06-08-2007 11:33:55
i was thinking 5500-6500#'S
