power block
kendak
06-07-2007 11:51:14
Does a new 6-1 power block have sleeves ?? I don't see why it would...boring mine to 6.125 for CW aircraft pistons & don't want to get into a sleeve...thanks ..Kent
Drew
06-07-2007 11:58:48
 Re: power block in reply to kendak, 06-07-2007 11:51:14
ALL power blocks have wet sleeves in them. Unless it has had a repair sleeve installed at sometime in its life inside the factory sleeve, you will not have any problems. Have the machine shop finish the bore to about 6.117", check your ring end gap, and you should be good to go.
big block bubba
06-09-2007 16:35:09
 Re: power block in reply to Drew, 06-07-2007 11:58:48
"Have the machine shop finish the bore to about 6.117". With all due respect, this is not the way it's done. Take those pistons to the machine shop and ask them to measure the pistons and bore the block .012" larger than true piston size. My 2 cent bet will be a finished bore of 6.123" to 6.128".
The real easy answer is to follow directions supplied by the folks who made the pistons.
i'm with drew
06-10-2007 19:24:54
 Re: power block in reply to big block bubba, 06-09-2007 16:35:09
Bubba, I don't think Curtis Wright is going to have instructions for putting their air cooled pistons into a liquid cooled John Deere. THey run really small. True, ideally, you'd measure the pistons and go from there, but being aircraft pistons, they run pretty true to size.
Drew
06-10-2007 13:58:59
I did not just pull that 6.117" number out of the air. I work in a machine shop and have bored more than one power block to use these pistons. At 90* to the wrist pin, I measured these pistons at 6.101"(I measured with a 6"-7"/.0001" micrometer, not dial calipers.) So .012" over that would be 6.113" If you get that small, there may be issues with the pin button/wrist pin assy. not having sufficent side clearance as well as the curvature of the rings not matching the bore properly.
