Super MTA What carb settings 170psi per cylinder
KIDD1954
06-06-2007 18:49:58
I need some advice I just put a 400 head on my super mta that is Not stroked but over bored to 4.310. My compression is now 165 to 170. I have a stock carb main jet untouched and I drilled out the bottom two holes in the metering stem.How do I test and set up my carb. It has the super m venturi I forget the number 27 I think and I also have the next size bigger venturi if I need it.
kidd1954
06-07-2007 20:18:27
 Re: Super MTA What carb settings 170psi per cylind in reply to KIDD1954, 06-06-2007 18:49:58
alright I put the #29 venturi in,kept the main jet original sm and put my metering stem in with the last two holes drilled out rns nice but I just did a pull tonight with it and it boged right down and seemed to have less power than before with the 8060. I didin't notice but I think it is lack of fuel under load. I have another sm carb that I already drilled out the main jet so I tried it with both stock and the other one and it smoked heavy with both, I had to turn the main in what looked like almost all the way.My old setup I would lose traction now I lose power in same gear.Help by the way chad that super h you built me rocks.
ChadS
06-08-2007 07:12:55
 Re: Super MTA What carb settings 170psi per cylind in reply to kidd1954, 06-07-2007 20:18:27
Check the head torque, may have loosened up. How big did you drill the metering stem holes? Too big of hole in the stem and it will run very rich. The 29 is more of a high rpm venturi, the 27 best for low end torque. Let me know what size bit you used for both main jet, and the metering stem, may be oversized. What kind of fuel? a good 89-92 octane pump gas should be sufficient in your SMTA. Tell me more about that Super H!!! Chad
kidd1954
06-08-2007 16:37:20
 Re: Super MTA What carb settings 170psi per cylind in reply to ChadS, 06-08-2007 07:12:55
I used a number 44 drill bit and the idle adjustment is on the top just under and to the left of the manifold. My original carb bowl that I drilled to #44 has a s 3 or 5 3 stamped on the outside of the bowl.I checked the plugs after the pull and they were clean no color no black or brown almost white but not.The bottom of both bowls have a brass screw on the bottom, but only the one comes out when you take out the metering stem out. Maybe the other is just stuck. Whats your email?Thanks
ChadS
06-08-2007 20:27:04
 Re: Super MTA What carb settings 170psi per cylind in reply to kidd1954, 06-08-2007 16:37:20
Its a late SMTA? It has the new style throttle body, with the old style bowl. I usually find em cracked. But, heres a few things to try. Make sure the passages in the throttle body are open. above the venturi, there should be 2 holes in the side of the bore of the carb. The very top is belived to be for the idle, and the bottom hole is the secondary fuel circuit. See, these carbs have 2 ways of delivering fuel up thru the manifold, where the older M style carbs, have only one for its fuel delivery under a load. If the passage gets blocked, its back to going thru the main jet and the metering stem, like the stock M. The new style carb, has a second port above the venturi, that delivers fuel into the already premixed fuel from the meterting stem, that has already passed thru the venturi. It is below the throttle valve, or butterfly, so, I imagine it draws fuel when its opening thru to wide open, and shuts off when its back to idle. Early 6 cyl carbs are simular in design, but the bowl was upgraded as well. They used a small main jet, and a large metering stem, to keep the fuel leaner, so it has enough fuel to mix in with the fuel going thru the second port above it. They also used a large venturi with this setup, cause it can deliver enough fuel to feed it when tuned in. Thats where the old style bowl needed the upgrade,, cause the metering stem was so small, and with both the main jet and the lower holes of the stem opened up, it now makes the fuel too rich out of the metering stem, especially when a smaller venturi is used. So either a stock stem, or swap out to a 6 cyl bowl to match up the upgrade. Thats what I think on the carb,,, but before, take the intake off, and use a sealer of some sort around the intake port. Sometimes the manifolds warp, so can the surface of the head and create a vacuum leak, which can cause a rich lean condition. Chad
kidd1954
06-09-2007 06:17:42
 Re: Super MTA What carb settings 170psi per cylind in reply to ChadS, 06-08-2007 20:27:04
So use a stock stem with the drilled out 44 main bowl and just use the needle to tone it down? When I tried this combo it still smoked.
ChadS
06-09-2007 07:43:54
 Re: Super MTA What carb settings 170psi per cylind in reply to kidd1954, 06-09-2007 06:17:42
I think its plugged up inside the throttle body on the idle side. Will it idle all the way down? say under 500 rpm? If the idle side is pluuged, it will try to pull the fuel from the metering stem, or the closest place it can get it. It will be rich cause its trying to run off the main jet, or the hole further up the throttle body, or both. If it wont idle down, and run smooth, and not load up. Make sure the bowl is not plugged up, so think of pulling the whole carb off and blow it out with high pressure air, (wear safety glasses) make sure, that all the passages have alot of air passing thru, Ive used MIG welder wire and poked thru the passages, found some debris air would not loosen up. If that dont help, [email protected] SO,, How is that Super H doing? I know how its H counterpart I have had done quite well a few weeks ago! Had 60+ feet on em. Chad
ChadS
06-08-2007 08:43:12
Where is the idle adjustment screw located? Is in the side of the throttle body, or up on the flange where it bolts to the manifold? Also, does it have a screw in metering stem, or does it have a brass plug that it threads into? Chad
kidd1954
06-07-2007 20:20:27
sorry I tried both metering stems
ChadS
06-07-2007 08:08:51
Start with a .100 size drill bit on the main jet, test to see if you can make it run rich at full throttle with no load. Incrase drill bit size by .015 at a time till it smokes with the adjustment screw backed out. Then turn it in enough to whrere it gives a puff of smoke out the exhaust upon acceleration. If you do the jetting right, it will be just like a stock carb set up on the adjustments, maybe 2 to 2.5 turns out and its getting rich. the 27 venturi will be ok for low end power, a 29 will be ideal. Chad
kidd1954
06-08-2007 06:24:20
 Re: Super MTA What carb settings 170psi per cylind in reply to ChadS, 06-07-2007 08:08:51
alright I put the #29 venturi in,kept the main jet original sm and put my metering stem in with the last two holes drilled out runs nice but I just did a pull tonight with it and it bogged right down and seemed to have less power than before with the 8060. I didin't notice but I think it is lack of fuel under load. I have another sm carb that I already drilled out the main jet so I tried it with both stock and the other metering stem one and it smoked heavy with both, I had to turn the main in what looked like almost all the way.My old setup I would lose traction now I lose power in same gear.Help by the way chad that super h you built me rocks.
mikes600
06-07-2007 14:44:16
chad, do you build a posi unit for a MH44?
ChadS
06-07-2007 17:55:04
 Re: Super MTA What carb settings 170psi per cylind in reply to mikes600, 06-07-2007 14:44:16
Yep. Chad
mikes600
06-07-2007 18:34:30
 Re: Super MTA What carb settings 170psi per cylind in reply to ChadS, 06-07-2007 17:55:04
Send me your email,
