Weights weight
smdv806
05-30-2007 13:18:56
How much do the one piece IH wheel weights weigh? These are flat on the back and slightly curved at the top. The main four holes are about 12 inches apart.
Also how much does a John Deere suitcase weight weigh? How much does a IH suitcase weigh?
G/MAN
05-30-2007 17:13:03
 Re: Weights weight in reply to smdv806, 05-30-2007 13:18:56
The full-size Deere suitcase weights will fall in the 90-100 pound range. Keep in mind that there are a few different Deere suitcase weight designs out there depending on what tractors they're designed to fit (weights that came with 4440s are different from a weight for an 8200) and that the actual weight will differ some from style to style and even weight to weight. But even with the different styles, they all pretty much mount the same and usually can even be mixed and matched on the same bracket and bolted together.
champspa
05-30-2007 13:46:13
a farmall wheel weight ways 144 and half weight 72
hang on's are 75 and 100 I think. front wheel 42.
side frame for sm-450, 116 front for 560 and 340 and the like is 80 don't do Deere
