MM ZTU vs. ZAU Gearing
MM ZAck
05-29-2007 16:17:29
Guys, I'm getting near completion with my MM ZA, setting it up for pulling with a bit of motor work. My question is I notice 1st and 2nd gear are way farther apart on the ZAU than a ZTU. The ZTU runs 1st: 2.2mph, 2nd: 2.6mph. The ZAU runs 1st: 2.4mph and 2nd: 3.6mph. I was hoping to pull in both 1st and 2nd with my ZA at 228CID, but that might not be possible since 2nd is so fast. Is a ZTU better for pulling because of gear selection? Can you swap gears between the two trannys? The tractors weigh about the same and I'll be weighting my ZAU for 4000lbs.
LW
05-30-2007 06:35:04
 Re: MM ZTU vs. ZAU Gearing in reply to MM ZAck, 05-29-2007 16:17:29
Transmission totaly different from ZT to ZA the bull pinions and bull gear are different. The ring and pinion is the only thing they share, the carriers are different and pto shafts.You want to stick with the ZA trans its a lot better. The ZA bull ratio is 5.66:1, ZT bull ratio is 4.714:1. YOU can change the carrier and bull pinions and bull gears in your ZA to ZT style but make sure you get the ZT carrier. Stock ZA 3rd gear has 20 teeth the ZT is the same. Stock 4th in the ZA has 24 teeth driving in a ZA its 23 teeth. THe constant mesh is very slow in the ZT thats why the bulls had to be so fast. THe ZA constant mesh is 33/22, the ZT is 38/17. I did one of these trans with 4th gear as a 24t driver,3rd as a 22t driver then 2nd as a 20t driver, thats about 2 mph apart at our super (like div4/5) rpm's of 2,500.
MM ZAck
05-30-2007 08:29:47
 Re: MM ZTU vs. ZAU Gearing in reply to LW, 05-30-2007 06:35:04
Wow, that's great information. I guess my thought was to try to change the ZA's 2nd gear set to a 2nd gear set out of a ZT. This might make a difference in reverse too since they are driven by the same gear. That would give you 2.4mph 1st gear, and 2.6mph 2nd gear (stock rpm). We only run 10% over stock rpm and I'm looking for a slightly faster 2nd gear for soft tracks. The upper and lower transmission shafts are both JT part numbers in my ZA parts book, which I'm assuming you should be able to put ZT gears on those shafts, no? Is it possible to swap the 2nd/reverse set of gears?
Thanks, Zack
LW
05-30-2007 18:19:04
 Re: MM ZTU vs. ZAU Gearing in reply to MM ZAck, 05-30-2007 08:29:47
The reverse sliding gear won't interchange because the rear constant mesh it engages with is 33 teeth instead of 38 in the ZT. YOu could change it at the front speeding up reverse and 2nd gear, YOu could take out 4th/1st slider and remake it. If you just want a faster 2nd the easiest thing is to change that front constant mesh.
MM ZAck
06-01-2007 15:42:53
 Re: MM ZTU vs. ZAU Gearing in reply to LW, 05-30-2007 18:19:04
Interesting. What if I want to make 2nd slower though and not affect 1st gear? Is that possible? Also, when you changed gears to make 2nd, 3rd and 4th about 2mph apart, were you mixing and matching stock parts from both tractors or did you have to make custom gears?
LW
05-30-2007 06:38:36
and also if you are wanting to gear down you could put the ZT trans in with the ZA bulls and it would get really slow.
rpllr
05-29-2007 18:29:35
Some of the early zt tractors were on 36" tires. that could make up some difference between the 38" on a za. there could be some difference in the tranny but i bet the pinions are the same. Your manuals should tell you the ring and pinion size. AS far as weight there is probably not to much difference, I had a za down to about 3500 with more cubes than you and it didn't like second gear in the 4500.
