Murphys roller rocker arms
potentpuller
05-29-2007 06:38:35
Has anyone used a set of 2.15:1 ratio rockers from Murphy's Motor Service in their Unstyled A?
How much HP can I expect to gain?
Also if anyone can tell me the stock rocker ratio that would be great.
The Potent Puller
Mike n Mo
05-29-2007 08:14:19
 Re: Murphys roller rocker arms in reply to potentpuller, 05-29-2007 06:38:35
The stock rocker is 1.5:1 on a styled A, so I would expect the same on an unstyled, although the assemblys are somewhat different. I saw a 4hp gain on an otherwise stock JD 60. Your choice of cam and other engine mods will change the results you see. I had a 12 hp gain on a bored/stroked JD A with a performance cam and Jerrys head over stock rockers. Mike
