JD A piston clearance ?
pulls other bra
05-25-2007 10:43:54
I know very little about 2 cyl pullers and less about airplanes.A friend is building a 6.125 or 6.250 stroker with airpl;ane pistons.Varios builders haved quoted clearances all above ....020 This seems alittle excessive even for a forged piston.I know of a similar A that was 5.75 @ .021 that thing hammered worse than a 730 diesel which by the way is .016 .Any knowledgable info would be appreciated.Thanks.
skip 33652
05-25-2007 18:41:53
 Re: JD A piston clearance ? in reply to pulls other brands, 05-25-2007 10:43:54
those radial aircraft engines used lots upon lots of clearance .025 + is normal the reason for this was the air cooled cylinders grew and shrank alot. one instance is high leval flight retard throttles and dive to lower altitude then fire wall engines and hope they ran and didn't seize up. these engines were built for war use not pleasure flying and longlivity and oil consumption was not a big issue.if you use .002" per inch of bore and add a thousands or two you should be fine. Paul
ToddF
05-25-2007 13:32:39
I used 6.123" diameter Pratt and Whitney aircraft pistons in my JD70. Apparently the rule of thumb for aluminum pistons in cast iron is .002" clearance per inch of bore diameter. So... 6.123" x .002" = .0122" of clearance, I used .014" clearance just to be safe and she still is running fine, that was six years ago.
Drew
05-25-2007 10:58:31
You are probably talking about the 6.125" bore Curtis Wright airplane pistons. I think mine measured 6.101" 90* to the wrist pin. In my opinion that is too much clearence built on for a 6.125" bore. On the blocks I have bored to use these pistins I usually try to hone to a finish bore of about 6.117". If you do this, you need to check your ring gaps and file them if necessary because you close the ring gap about .003" for every .001" you shrink the bore.
