flywheel
kendak
05-25-2007 07:31:54
Without taking them off where can I find the weight of flywheels off....60 ,unstyled A , styled A ,electric start ,hand start, etc....thanks...Kent
Mike n Mo
05-25-2007 20:36:48
 Re: flywheel in reply to kendak, 05-25-2007 07:31:54
Kent, I don't know the weights of all of them, But there were 2 different ones for early styled with electric start. One is 100#, and the later ones are 130#. These are for 488,000 thru 584,000 The hand start flywheels should be about the same as the light one. The late styled flywheels are smaller in diameter than the early flywheels, and the diameter of the crankshaft splines is larger on the early cranks by about 0.020". Mike
