Repair water jacket on Super M block
Mississippi moo
05-24-2007 18:45:26
Guys, what is the name of the 2-part epoxy product that is used to pour inside the water jacket cavity? I know alot of pullers use it to make the block stronger. I have a super M block that has pin holes at the bottom of the liner bore on 2 of the cylinders. Is there a better product than JB weld to wipe on the inside bottom of the bore before the liners are installed?
turbos10
05-25-2007 17:14:43
 Re: Repair water jacket on Super M block in reply to Mississippi moonshiner, 05-24-2007 18:45:26
It is called "Hard Block", but there are also other brand names. Search jegs.com or summit.com for "block filler" and you should find what you need. You will want to have the finish hone done after the hard block has set as it can cause some block distortion.
