Sealant on copper gasket?
Shutt 30
05-13-2002 15:28:20
What are you guys using on a copper head gasket? Copper coat, Spray tack, or what? I don't have much room between cyl. and head bolt hole and don't wan't to torque to tight for fear of pulling the threads up. Thanks
Brad
05-14-2002 13:46:17
 Re: Sealant on copper gasket? in reply to Shutt 30, 05-13-2002 15:28:20
Maybe try a head stud rather than a head bolt, that way you know the stud is threaded all the way to the bottom of the hole. Then put the head on and torque the nut.
Shutt30
05-15-2002 07:10:01
 Re: Re: Sealant on copper gasket? in reply to Brad, 05-14-2002 13:46:17
Thank you for catching my mistake. They are studs not head bolts like I wrote.
John
05-13-2002 16:07:34
careful, don't want too much compression, 200psi is MAX in my book, and, we just use copper coat and have the block fire ringed. (just my thoughts)
John
how much power u expecting to get outta the ol'30?
