would this work?
puller man
05-23-2007 14:12:52
I have a farmall H and im going to change out pistons and sleeves. Can i just put Super H piston"s and sleeve in there without boring block. I need more power and was just wondering about that. I am on a budget with this tractor and on a deadline so if any help would help me that would be great.
Eugene Cascaddan
05-23-2007 14:34:03
 Re: would this work? in reply to puller man, 05-23-2007 14:12:52
If you really want a hard puller...replace your cam with a full lift cam. You will probably need a full service machine shop to modify your existing cam. Then she will pull like a John Deere.
puller man
05-23-2007 14:41:55
 Re: would this work? in reply to Eugene Cascaddan, 05-23-2007 14:34:03
I Already put a cam in it. I need to know if the pistons will work. I already got a couple of tractors that will beat A Deere i need my budddies to Beat them.
Andrew Z
05-23-2007 18:50:48
 Re: would this work? in reply to puller man, 05-23-2007 14:41:55
No, with out boring the biggest the H will take is 3 7/16" the Super H is 3 1/2" stock. If your goign to bore it out then go to 300 pistons that way you can still run a sleeve or you coould run a piston right in the block with no sleeve its up to you.
Andrew
BF8690
05-24-2007 13:10:13
 Re: would this work? in reply to Andrew Z , 05-23-2007 18:50:48
How big are 300 pistons? What is the advantage to running 300 pistons?
Andrew Z
05-25-2007 06:07:20
 Re: would this work? in reply to BF8690, 05-24-2007 13:10:13
300 pistons are 3 9/16" giving a total displacement of 169CI. I my opion there is not that big of a diffrence between the 164 and 169.
Andrew
