Need info on V-8 diesel fuel injection pumps.
Moulder
05-20-2007 16:47:14
I am toying with the idea of building a hot 7.3 Powerstroke for a pulling truck. I would like to get rid of all the electric and hyd. parts that operate the fuel system and go mechanical. What kind of injector pump would be a good choice? I know there is a V-8 Perkins and the 3208 Cat. I am looking for something that can be turned up easy and is somewhat common in the tractor pulling feild. Can anyone share some information?
buickanddeere
05-22-2007 08:09:28
 Re: Need info on V-8 diesel fuel injection pumps. in reply to Moulder, 05-20-2007 16:47:14
That would be a step backwards going mechanical. The aftermarket is loaded with bolt on HP adders that work. They will also monitor engine paramaters and reduce fuel if too EGT is too hot. And shut down the engine on low oil pressure etc. How are you planning to stick a ordinary injector way down there in the engine and seal up the oil & fuel passages too? Finding a place to drive that injection pump will be a challenge too.
