went to chasis dyno with wd friday
mlpankey
05-20-2007 14:57:02
4.125bore 5.80 stroked 226 made 70 horses at rear wheels in third gear all dyno pulls were made in third . wandering what the loss through all those gears were .anybody have a formula for the loss through tranny to rear after all theres alot of gears turning .
buickanddeere
05-22-2007 08:12:42
 Re: went to chasis dyno with wd friday in reply to mlpankey, 05-20-2007 14:57:02
Best was to test & tune a tractor I've heard of. The dyno is more accurate than the seat of the pants. Easier and safer to monitor EGT etc too. 1% loss per gear mesh is a rough rule of thumb. The flexing of the tires will use a bit of HP too.
ChadS
05-22-2007 08:46:06
 Re: went to chasis dyno with wd friday in reply to buickanddeere, 05-22-2007 08:12:42
I wonder if Knobby turf tires would work on that setup, maybe a smoother ride while testing? the 15.5s would rob some power,, wonder what the differences would be with different size tires? Chad
Real Puller
05-22-2007 12:51:12
 Re: went to chasis dyno with wd friday in reply to ChadS, 05-22-2007 08:46:06
I"m sure it won"t work as good as your magic dyno.
JDGnut
05-21-2007 17:42:10
Was it an exceleration dyno.. or a load dyno?? (I'm guessing from you discription it was a load dyno... mustang??)
It would have been interesting to see the results in different gears.
JDGnut
mlpankey
05-21-2007 15:12:42
well to answere some .the dyno is a 1800lb drumm with a electric brake and computer software . that measures the rpm from the crank and rpm of drum .elevation humidity and air to fuel ratios are also looked at.and yeah ive not really ever seen 1 horse per cube on pulling tractors . i didnt think the question was stupid because some autombiles parisitic loss to rear wheels is 70 to 100 horsepower loss depending on transmission.since the dyno was really designed for automotive use these numbers of loss are known. for tranny of diferent makes .as for truly red the last years motor had know promblem with 100 horse h,s and this one feals alot stronger. oh i did pull 15.5 38 cut tire on the dyno. they bounce bad but it was agood way i think to break the motor in .
mlpankey
05-21-2007 15:21:38
 Re: went to chasis dyno with wd friday in reply to mlpankey, 05-21-2007 15:12:42
i need to apologize to truly red its the unknown puller that i confused .truly red youre question was legitimate and i respect it and you sir. anyone who calls someone stupid needs attitude adjustment .i hope to run into this unknown at pulls if he,s not scared to reveal himself.
unknow puller
05-21-2007 11:49:45
think about it stupid//////////////
4010gas
05-21-2007 15:08:46
 Re: went to chasis dyno with wd friday in reply to unknow puller, 05-21-2007 11:49:45
Did you know before, and then something happened and now you unknow????
trulyred
05-21-2007 10:42:26
I would like to know more about this chassis dyno. I"ve been thinking of designing a platform with a roller that you could connect a pto dyno to. What type of tire did you use, I wouldn"t want to use my cut pulling tires, but I think you would want something with about the same circumference to know what HP your getting to the ground. Thanks! Do you have pics?
MolineManG1
05-20-2007 19:59:59
I would like to know how that compares to your pto horsepower?
Greg_Ky
05-20-2007 19:44:53
Figure even if you are only making one horsepower per cubic inch @ 310CID. that is a lot of loss.
Eric Bloom
05-21-2007 14:05:45
 Re: went to chasis dyno with wd friday in reply to Greg_Ky, 05-20-2007 19:44:53
i would like to see any antique tractor motor that makes anywhere close to 1 hp per cubic inch. at 20% over rpm i don"t see it happening.
i'm sure someone will tell me i'm wrong though.
