M oil capacity with 1 girdle
turbos10
05-17-2007 21:21:09
Hey all,
I was wondering if any of you are running a girdle on an M and what the oil capacity is with the pan one inch lower. I would like to run as much oil as possible.
Thanks!
JDGnut
05-20-2007 19:19:28
 Re: M oil capacity with 1 girdle in reply to turbos10, 05-17-2007 21:21:09
I guess you didn't make LeRoy.. haha.. No loss.. it was not a very good turn out.. Going to make it to Hillsboro?? I have a few questions for ya... haha... I don't think you'll see my G for a while.. as I just going to keep it in the shop until its finished... JDGnut
turbos10
05-20-2007 19:55:47
 Re: M oil capacity with 1 girdle in reply to JDGnut, 05-20-2007 19:19:28
Yeah I missed LeRoy. Got the frame connectors and fenders finished tonight, so the chassis is done. A few little odds and ins and finish tire cuttng is all that is left, so I should make Hillsboro. You know when and where the pull is?
I could not stand to keep mine in the shop till it is finished. I can pull it ugly if it runs, so it may be another year before paint.
What questions...email me.
JDGnut
05-21-2007 17:37:12
 Re: M oil capacity with 1 girdle in reply to turbos10, 05-20-2007 19:55:47
I'm just guessing the pull starts at 10... (which means closer to 11... ) The pull is East of town.. (East of I35) Take Hwy 22 East towards Corsicana. About 1/2 mile past I35, on Hwy 22, there's a small road to your right. (The college is on your left.) They will have signs up. Then go about 2 miles.. it will be on your left.. It turns to gravel, and you'll think you are in the wrong place.. just keep going..
turbos10
05-18-2007 16:41:55
I understand the concerns, but I can assure you I know what I am doing by raising the capacity; this is a high RPM turbocharged engine with grouted block and a tiny one core radiator. Adding oil adds thermal capacity...what is what I want.
Can anyone answer the capacity question?
buickanddeere
05-18-2007 22:19:03
 Re: M oil capacity with 1 girdle in reply to turbos10, 05-18-2007 16:41:55
Run it on the full mark of the dipstick. If the rad is so small and you are worried about having enough mass to absorb combustion heat. How about an running alcohol blend fuel. And carrying a few gallons of water to "boil off" as steam to absorb heat. Nothing like giving us the details a day or two after you ask the question. If you really want to add "thermal capacity" via the lube oil. How about a deeper oil pan? Have you figured out how many btu a quart of oil absorbs to be heated from 150F to 250F? And compare it to the btu's rejected by a 125HP engine running at full power for approx one minute? Plus idling around time before and after the pull. If you need to dump heat, just boil some water.
turbos10
05-18-2007 22:28:11
 Re: M oil capacity with 1 girdle in reply to buickanddeere, 05-18-2007 22:19:03
The problem with a grouted block is with the oil being able to reject heat as it normally would in the bottom of the block and lower cylinder wall area. That is what I mean by adding thermal capacity. The pan is deeper due to the girdle...hence the question.
The engine is more like 500HP and will run about 10 seconds at full power since ground speed will be around 20mph. And I am running two stages of water injection with the capability of ethanol blending....which as you mentioned will help with engine heat. However, the oil is still going to get hot quickly.
Greg Lussetto
05-18-2007 17:33:12
We run 1 extra quart in our 560's.
Greg
turbos10
05-18-2007 18:00:37
 Re: M oil capacity with 1 girdle in reply to Greg Lussetto, 05-18-2007 17:33:12
Thanks, Greg. That was what I was thinking about going with, but I wanted some feedback to confirm.
42Farmall
05-18-2007 14:39:13
I'd be more concerned that the pickup was dropped also. The lower oil level won't hurt it if you keep the same amount in the pan.
buickanddeere
05-18-2007 06:40:05
Extra oil just takes HP as it's whipped around by the crank. And frothy oil full of air bubbles is not an ideal lubricant. Deep sump oil pans for wet engines and dry crankcase systems are used to get oil away from the rotating assembly.
