Michigan pulling master schedule?
Mopower
05-15-2007 11:06:22
Hey fellas. Every year someone seems to compile a list off most Michigan club's pulls with contact numbers. Anyone do that yet? Marilyn Cotton used to. Just looking for Flat River, County Line, Prarieville, Lakeshore, Remus, EMTPA, Leslie, Noon's, etc. Thanks. Someone's got one floating out there somewhere.
Ethan
Bus Man
05-16-2007 08:10:57
 Re: Michigan pulling master schedule? in reply to Mopower, 05-15-2007 11:06:22
Flat River put together a schedule that has it's pulls, Clintonia, County Line, and Lakeshore, plus a few others. I have a hard copy, but not one on my computer. I can make a copy and mail one to you if you like. I plan on being at Flat River's first pull in Lowell this Saturday, if everything goes as planned. Weigh-in at 3 pull starts at 5. EMTPA has a web site with their schedule and Leslie has their first pull on 5/26 and then on the 2nd Saturday of each month through October. They have changed their classes along with some rules. I also have a hard copy of them. They have farm stock, antique, and antique plus and now have provisions for cut tires. I don't have any info on the pulls at Remus. Hope this helps.
Mopower
05-17-2007 12:53:38
 Re: Michigan pulling master schedule? in reply to Bus Man, 05-16-2007 08:10:57
Yes, I"d love a copy of the schedule. I may go to Lowell on Saturday even if only to watch. Bring a copy along if you can. Thanks Mr. Kinney!
Ethan
A.P.
05-16-2007 09:32:25
What classes are they pulling at Leslie and what changes to the rules has there been?
Bus Man
05-17-2007 03:22:28
 Re: Michigan pulling master schedule? in reply to A.P., 05-16-2007 09:32:25
Classes: 1. Antique: 59 and older. Max tire size 0-6500lb 229 sq in. 6501-10000 300 sq in. top cuts only, 3mph, 3 beeps on horn, weights 11 ft. forward of rear axle and not behind radius of rear tire. Stock RPM 10% margin. Hitches 18" back, 18" high. Wheelie bars per NATPA chart, W/O wheelie bars hitch must be behind radius of rear tire. Weight classes 0-2750, 3000lbs. and then every 500lbs up to 6500. then 7500, 8500, and 10000lbs.
2. Antique plus: 59 and older. Tires 18.4X38 any cut. Speed 4.5 mph. Front weights 11 ft. from rear axle. RPM 20% margin. Naturally aspirated. Wheelie bars and kill switches. Hitch, 18" back 20" high Weight classes 0-3500 and every 1000lbs up to 8500
3. Farm stock: Tires 24.5X38 noncut. 5MPH. Hitch 18" high behind radius of rear tire. RPM 10% margin. Engine, frame, turbo and pump to be as came from factory.
Superih
05-16-2007 08:43:47
 Remus schedule in reply to Bus Man, 05-16-2007 08:10:57
Remus schedule
6/2/07 12pm Remus Tractor Trans-sled
6/22/07 7pm Blanchard Trucks Trans-sled
6/23/07 12pm Blanchard Tractor Trans-sled
7/7/07 12pm Remus Tractor Trans-sled
7/20/07 4pm Remus Tractor Trans-sled
7/21/07 12pm Remus Tractor Dead boat
7/22/07 12pm Remus Tractor Dead boat
8/3/07 7pm Barryton Trucks Trans-sled
8/4/07 12pm Barryton Tractor Trans-sled
8/24/07 3pm Blanchard Tractor Trans-sled
9/1/07 12pm Remus Tractor Trans-sled
