Steel flywheels
Shaggy
05-13-2007 20:20:58
Is there anybody that make steel flywheels? I Thinking about putting together a C-153 for my Super C that can turn a few RPMS but the rules around here require a steel flywheel. And from what I have read here is that you are on borrowed time if you turn a stock flywheel much over 3000rpms and then you are pushing it. Thanks Shaggy
turbos10
05-14-2007 19:29:36
 Re: Steel flywheels in reply to Shaggy, 05-13-2007 20:20:58
Any reputable machine shop should be able to make one. I would look into a steel automotive flywheel and clutch setup that you could adapt over. Custom machine work can get very expensive. Darin Rursh might have a source. He does tons of slippers and I am sure some of it is custom.
Shaggy
05-15-2007 05:53:46
 Re: Steel flywheels in reply to turbos10, 05-14-2007 19:29:36
Thanks for the idea. What type of steel should be used? Its probably best to let the machine make that choice.
Thanks Shaggy
turbos10
05-15-2007 19:55:27
 Re: Steel flywheels in reply to Shaggy, 05-15-2007 05:53:46
Not sure what type, but I think most the automotive are 1053.
