Farmall M Hubs
DC_PA
05-07-2007 20:39:48
Hi! Where can I get a set of 9 bolt hubs for a M? light weight and strong. Any help appreciated. Thanks, DC
MJF
05-09-2007 13:33:46
 Re: Farmall M Hubs in reply to DC_PA, 05-07-2007 20:39:48
Hubs that are off a IH 560, will they work on my M
Jim F.
05-09-2007 04:04:24
I have a set off of an 88 here in Western PA that will work on your M, 2.75 axle. Where in PA are you?
bm3501466
05-08-2007 09:56:20
An interesting story to accompany the statement of massey hubs being junk. My great uncle was telling me about the Super MD his dad bought new. A little later the Massey dealership challenged him to a plowing contest to advertise the 44. About as soon as they got to plowing a hub broke on the 44. Moral of story: The massey hubs that size were never good.
Ohio M
05-08-2007 06:34:03
There is a set of oliver hubs that will fit a M on ebay
BF8690
05-07-2007 22:11:23
I use JD 2010 hubs. My M is putting out 80 HP and I have had no problems at all with the hubs. A Friend of mine is using the JD 2010 hubs on his 560 Diesel and he hasn't had any problems either. I have read not to use Massey 44 hubs because they will not handle the power of a good M. Here is the kicker with the JD2010 hubs. You have to take one of you axel clamps and the JD 2010 hub to a machinist to have keys made for JD hubs that will accept the taper of the M's axle. The JD 2010 hub key is the same width as the the M but the 2010 key is square not tapered. I think it cost me $40 per key. I had them make new ones out of hardened steel. I got those hubs for $50 so it was cheaper than buying M&W hubs. M&W hubs can be found but the cheapest ones I could find were $500. I'm sure that they are out there for less, I just couldn't find them.
