foam sealant in rear end
MN Dave
05-07-2007 20:18:21
I've read some earlier posts that you can use the expanding foam sealant in the rear end of your puller (an M in this case) to displace oil/lighter weight. Do you have to put a sealant over the dried foam? How much foam is advisable to put in? Thanks for the help.
minnesota red
05-10-2007 17:26:54
 Re: foam sealant in rear end in reply to MN Dave, 05-07-2007 20:18:21
Dave,i was the one that posted that.
give me a call,i believe i know who you are.
Chad Peterson,number is in the book.
and to the other guy,although a M hold a bunch less oil than a 856 i lost 42 gallons of oil out of mine not pounds,gallons.
i would guess you could loose about half that out of an M and it will be the cheapest weight ever lost on a puller,atleast it was on mine.
RWWisehart
05-07-2007 20:23:10
Yes I read that, sounds like a lot of trouble to lose 30 lbs.
