Tire presure question
mikes600
05-06-2007 19:17:41
I"am pulling single cuts 23.5 x34"s . I get a good even bite on a track with packed dirt with plenty of moister.(6 psi).Same track, but dry and packed like concrete, tractor set up is the same, but getting alot of hop,while pulling. What i"am i doing wrong? Need more air presure, or less? Thanks
Mike Aylward
05-07-2007 06:39:38
 Re: Tire presure question in reply to mikes600, 05-06-2007 19:17:41
Mikes600, you are likely running way too low air pressure. A lot of people think their tires are out of round when this happens but usually this is not the case. Your tires will try to hook up but do not have enough air in them to support the sidewalls or tread, causing the tractor to "squat". When this happens, you lose drawbar height, causing the tractor to break loose and raise back up. This cycle repeats itself, causing the hopping you have experienced. Without knowing how heavy you are pulling, I would never run less than 10 lbs. of air in a larger tire and would probably go more than that. Hope this helps. Mike
Puller504
05-07-2007 03:53:46
Standard here is 1.5 psi per #1000 of tractor weight in any class of STOCK pulling up to #12,000. Adjust for effect from there. Hope this helps, Don
The Preacher
05-07-2007 16:47:35
 Re: Tire presure question in reply to Puller504, 05-07-2007 03:53:46
I agree with Puller504 on this one. I run 7 lbs. of pressure in 5000 and 5500, and the tires usually hook until they stall the engine out. But, I run a standard frame, too. I"m not sure about a rowcrop.
