farmall hubs and John deere rims
High Octane
05-03-2007 06:26:11
will John deere double beveled rims (like off a 3020) fit on the IH 450 cast iron centers with either the 450 driving lugs, or JD driving lugs? If this can work, its a make shift 14 inch rim that might fit with little or no modifcation? Thank you
Donnie Baker
05-05-2007 16:07:10
 Re: farmall hubs and John deere rims in reply to High Octane, 05-03-2007 06:26:11
Hey dude the double bevel rims will work on any hub that is designed for double bevels no matter the mfg. as long as the diameter is the same say 38" to 38" same thing with drop centers the tractor mfgs. did not make their own rims they were bought from some rim mfg. I gotta go
Mike n Mo
05-03-2007 13:28:58
The rims should interchange without any problems. You probably will want to use the IH drive lugs, I don't know if they will interchange. Mike
