oliver77
ken77
04-26-2007 09:31:52
Is it possable to get 80to 100 hp out of a oliver 77 with some modifications?
770
04-27-2007 17:03:06
 Re: oliver77 in reply to ken77, 04-26-2007 09:31:52
Yes.....
ken77
04-27-2007 09:42:00
If you are asking me how many hooks 20 to30 pulls and two to three classes each pull
pllr
04-27-2007 08:28:29
Hey stroker,
how many hooks per year???
stroker 88
04-28-2007 20:12:39
 Re: oliver77 in reply to pllr, 04-27-2007 08:28:29
on the average 4 hooks per night + occasional pull offs. about 20 nights a year. thats in road gear for 3500 & 4000 if the track is loose, 5 th gear for 4500 & 5000.
stroker 88
04-26-2007 18:33:20
had a 77 that was 4 1/8 by 5 3/4, took nine years of pulling before the crank broke. putting another one together right now. makes about 115 hp. only run 20% over on rpm"s , stock on the outside.
Bryce
04-26-2007 13:52:11
Easily,4.125 bore X 5.25 stroke.Plenty of room in the block for both.
lonestar
04-26-2007 10:58:34
you can possibly do it but you better have some other blocks laying around, like the other post says, it will be paper thin
rrlund
04-26-2007 09:53:52
Possible sure,but it won't be cheap. A guy here locally has an 88 dynoing 125.Stroked and bored. Bored so thin he had to fill the water jacket nearly to the top with filler to strengthen the cylinder walls.
