The Real Confederate
Hey
04-24-2007 18:45:30
Hey sonny I wanna send my M cam out to you to get ground, I sent you guys 2 emails but you must not have gotten them. My PC has been givin me problems so it's prolly my problem. But what all info do you need? It's an M block(C-248) with 4 1/8" firecraters, stock stroke, 8574 gas head. Lookin to run between about 1700-2000 RPMs depending on track. I'll be pullin new 13.6's F&R. I need to know where to send it and what other info you will need. Thanks
dboll
04-25-2007 05:10:43
 Re: The Real Confederate in reply to Hey, 04-24-2007 18:45:30
regrinding a cam will eliminate 60 years of wear. Grind the cam to match the engine. Stock engine will benefit from a grind with more lift but not much if any more duration. as the engine gets bigger the cam grind can be more agressive.
RWWisehart
04-24-2007 18:57:45
Waste of money if not stroked.
ok thanks
04-24-2007 20:30:05
 Re: The Real Confederate in reply to RWWisehart, 04-24-2007 18:57:45
I'm not building an all out pulling tractor, I don't have the money to build an all out pulling tractor. In fact if there wasn't a 1" wide by 1/8" deep groove in the #2 sleeve due to a broken ring which has been like that for over 15yrs it would still be farming/pulling. Oh yeah don't forget the crank was wiped, the machine shop had to go 20 on the mains and 30 on the rods and I was still pulling it competitively. So I will say Thanks for voicing your opinion but unless your buying me a stroker crank I'm not putting one in. Maybe some day when I have money that has no better place to be I'll build a hot tractor until then I will pull for FUN and and I suggest others try pulling for FUN. I know thats a swear word on this forum
Jim Johnson
04-25-2007 03:51:42
 Re: The Real Confederate in reply to ok thanks, 04-24-2007 20:30:05
So in you're way of thinking a tractor has to be mostly stock to have FUN?
not really
04-25-2007 13:56:53
 Re: The Real Confederate in reply to Jim Johnson, 04-25-2007 03:51:42
Never said that but he says I'm wasting money if I don't stroke it, we use all of our tractors on the farm and I am not going to use a stroked M on the farm. Since I had to rebuild the entire engine I thought I'd make it work a little better to play. I don't pull in money pulls or nothing like that just like to have a little fun in the spare time. Thats it, I think it's awesome that you guys build over 500ci M's with 18.4x38's. I'd love to have one of them but I don't nor do I have the time and money to build one.
