camshaft degree wheels
jdjack
04-22-2007 19:35:43
I have a 44 JD A that I will need to degree the camshaft, in the future.
I have been looking at degrees wheels.
What are some types that you guy are using. Or what kind do you recommend.
I do not what to make one.
Thanks
Greg_Ky
04-23-2007 15:24:45
 Re: camshaft degree wheels in reply to jdjack, 04-22-2007 19:35:43
Jack just about any degree wheel will work providing that you have the proper adapter for the crank bolt. (you want it to fit snug with no play) The larger the wheel the more accurate. Use a positive stop to determine top dead center. Use your @.050 lift specs. on your cam card to degree. Good Luck.
in a pinch
04-22-2007 20:15:15
A pizza box, compass, protractor, and some triangles. Cost about $15 for the pizza and very accurate for what it is.
