Pistons for stroker M crank
Kenny Chinsey
04-22-2007 11:23:30
I am needing advice on what piston will work with a 5 3/4 stroked M crank. I will be using stock M rods and looking for 4 1/8 bore size. Any thoughts or ideas would be appreciated.
Thanks
ChadS
04-26-2007 07:45:10
 Re: Pistons for stroker M crank in reply to Kenny Chinsey, 04-22-2007 11:23:30
Well, you can get you a set of 450 pistons, and whack off the material to make them clear, you can also drop the wrist pin location down a little, and not have to remove so much off the pistons. Cyl head choice,,, 450 head, or a 8060 gas head clearenced for the bigger domed pistons. Would run good on E85 with some pump gas to tame the E85 down, but, its not 10 dollar a gallon fuel. I have kits made to spec for up to 6.125 for 4-1/8th bore. Chad
turbos10
04-23-2007 16:16:32
I had Murphys Motor Service build a set of pistons for my M. They are really nice pieces cut from Arias forging.
trulyred
04-23-2007 15:20:45
I have a set of used M&W AP75 large pin that are 4 1/8 and have been modified for more compression.
