head
kendak
04-20-2007 06:19:27
Building a 36 "A" puller ..6" #1 powerblock x 9" stroke...can't find a Hiesler head ..I have a late model gas head & a 60 fuel head what can be done with either one of these & who do you recommend to do the work??...thanks for the help...Kent
turbos10
04-23-2007 16:14:51
 Re: head in reply to kendak, 04-20-2007 06:19:27
Jeff at Murphys is great to deal with. Honest and keeps his commitments.
Rusty Junk TX
04-22-2007 04:41:03
By the time you find, buy, rebuild, and trick a styled heisler head, you can get a Jerry's head with matching manifold for about the same money. Jerry sold out and it is called Murphy Motor Sports (murphymotorsports.com). I run one on a 38 "A", #1 block, 9" stroke, and 6.100" aircraft piston. She gets it done. She got R done yesterday. 4600lb in 3rd gear, 5100lb in 2nd gear on a tight track.
Marcus
kendak
04-23-2007 10:45:35
 Re: head in reply to Rusty Junk TX, 04-22-2007 04:41:03
What rear tires do you run Marcus..thanks..Kent
Rusty Junk TX
04-24-2007 20:25:14
 Re: head in reply to kendak, 04-23-2007 10:45:35
16.9-38 cut Bridgestone on 16.5" rim.
kendak
04-26-2007 10:03:33
 Re: head in reply to Rusty Junk TX, 04-24-2007 20:25:14
Thanks for reply on tires ...Jeff won't be making any heads until late this fall or winter...I need a head now!!..thanks ..Kent
JPatton
04-22-2007 06:19:36
 Jerry's head in reply to Rusty Junk TX, 04-22-2007 04:41:03
I think you will have better luck at murphysmotorservice.com
Just trying to help
J
