14-9-38 Firestone tires on 12 inch rim?
Game Over
04-13-2007 15:52:22
Hi to all i need some advice!
i bought a new set of 14-9-38 firestone tires,and the rims i want to put them on are 12 inch rims, will this affect the way they will pull?
Any help will be much apprecated.
Kurt-Allispuller
04-20-2007 00:07:45
 Re: 14-9-38 Firestone tires on 12 inch rim? in reply to Game Over, 04-13-2007 15:52:22
I run my 14.9"s on a 16" rim and im un stoppable. I wouldnt go any less than a 14" wide rim. A 12" rim was made for a 13.6
barnstormer1
04-13-2007 18:06:31
14.9 - 38 6ply all traction field and road on a 12" rim with the correct air pressure (5-7 psi @ 4500 lbs) is a tough combo to beat. Provided you have a very good style of cut on the lugs if they allow cuts. Dont under estimate the value of air pressure, rim width and ply rateing (sidewall stiffness) cobination. This will often determine weather your in the money or not especialy at a dead weight pull.
jd lover
04-13-2007 17:00:26
they will be fine
jd lover
04-13-2007 17:00:19
they will be fine
