pistons
kendak
04-13-2007 06:06:03
Is the deck height higher on a JD 70 LP piston than a gas piston???..thanks ..Kent
JDGnut
04-13-2007 09:08:00
 Re: pistons in reply to kendak, 04-13-2007 06:06:03
Yes.. the 70LP pistons are taller.. I don't have two to compare.. but the head is basically the same between the gas and LP. The Piston are the difference in compression ratios..
(Getting hard to find the 70LP pistons..)
JDGnut
Mike Aylward
04-13-2007 10:49:31
 Re: pistons in reply to JDGnut, 04-13-2007 09:08:00
I would guess that the compression height on the LP piston is the same as the gas piston but that there would be no "bowl" on the piston head. In other words, the piston on the LP would be a flat top instead of dished. Mike
High Octane
04-13-2007 07:10:15
We have some super good, used 70 pistons if you need em. I can pass the contact info along if interested. They look like brand new.
