Magnetic tach sensor
LLT
04-12-2007 17:39:25
What company is marketing the magnetic tach sensor for the sled to plug into. Certain pull rules require the sensor and a wire going to the back of the tractor.
CrazyAllis Kurt Hamel
04-13-2007 16:56:47
 Re: Magnetic tach sensor in reply to LLT, 04-12-2007 17:39:25
We have the sensors used with the tachs we sell but you can pick one up at any heavy truck dealership.Freightliner will be the cheapest, just ask for a tach or single lead speedo sensor. If you want get a dual lead speedo sensor for an ECM controlled truck and you can run your tach and the sleds at the same time. The question I have is why they would want a tach for the sled, it seems to me if you check it after the pull like NATPA does you would do the same thing without adding the cost of the sensor to every tractor.Also sensor tachs are calibrated to the signal,ie. tooth count, so unless the tach is recalibrated to each tractor it would not be accurate. Kurt Hamel
fergfarms
04-12-2007 19:38:09
Agri-Tronix.com
