ANY MOLINE PULLERS, NEED HELP
NEW GUY ON THE
04-10-2007 14:38:35
JUST GOT A U YESTERDAY, FINALLY ONE THATS NOT A FAMILY HEIRLOOM, WHATS IS THE CHEAPEST WAY TO GET A LITTLE MORE POWER OUT OF HER, I AM GOING TO PULL HER TILL SHE BREAKS, THEN I AM GOING TO GET CRAZY
Mopower
04-16-2007 11:01:00
 Re: ANY MOLINE PULLERS, NEED HELP in reply to NEW GUY ON THE BLOCK, 04-10-2007 14:38:35
The cheapest way to gain power without too much machining costs is to simply to set over M5 blocks and pistons on it. The pistons are ever so slightly taller but if you order a thicker gasket from Lubbock, it takes up the difference. Because you go from 283 to 336 cubes, your compression goes up too. They bore to 4.81 if a fella wants. As far as bolt on? Use LP manifolds and slap a M670 venturi in your carb. Both pep it up just a tad. More money? Lets talk G crankshaft. That gives you a few more options.
ejr-IA.
04-10-2007 17:52:02
M5 LP manifolds and your carb.Lighten the govenor weights and a stiffer spring.High comperrsion heads ,don't know how far you want to go with it.
