attn chads 400 farmall
olly
04-08-2007 16:33:39
what kinda head gasket do i need for a 4.310 bore the stock one is overlapping and ive got into the water jackets what do i need to put on my sleeves
ChadS
04-08-2007 17:51:06
 Re: attn chads 400 farmall in reply to olly, 04-08-2007 16:33:39
Go thru at the bottom? Think about hard blocking up to the bottom of the water plate. Did you put rings in the counterbores? if not I think its at 4.5" across, so, a 450 gasket wont cover it. Copper gasket, or have a custom composite gasket made, or, rings for the counter bores and use the 450 gasket. It may overhang slightly, but not as bad, and usable. Im not sure if a 450 LP had a bigger gasket or not,,, heard it was, possibly seen it was years back. I fixed a 4-3/8 bore with no counter bore rings with a IH gasket, only overhung about .010 all the way around it, still together today,,,,, possibly a LP gasket. Id hardblock it, sleeve retainer by loctite is pretty good stuff,,, just depends on where the hole is located.
