tire ? Mike Aylward or anybody
div 3 type pull
04-06-2007 10:31:30
Currently pulling 5500 to 7500 want to drop to 5000 to 6500 lbs.A smaller wheel and tire will weigh less as wellas put more ground pressure in psi to the footprint.What is the ideal size tire for this weight range 5000 to 6500?Also at what wei9ght does atractor become so light a 18.4x38 will spin on top instead of digging in?Thank you.
Mike Aylward
04-06-2007 10:54:46
 Re: tire ? Mike Aylward or anybody in reply to div 3 type puller, 04-06-2007 10:31:30
You probably can still get along fine with your 18.4's. They usually are not the best choice under 5000 lbs. but work well over that. It also depends on how much power you have. If you have a pretty healthy tractor you will want to stick with the 18.4's. If you are running a more moderate power level a 16.9-38 might work a little better. Mike
