making a locked differential
posi1
04-04-2007 20:14:24
I have a John Deere A and was wondering what kind of ideas are there out there for a limited slip or differential lock out there that maybe you can lock in and then lock back out so you can turn. what kind of ideas are out there? i know it can be done, seen a G that they moved a lever under the seat to lock it in. thanks for any ideas.
Earl-IL
04-05-2007 08:43:41
 Re: making a locked differential in reply to posi1, 04-04-2007 20:14:24
Chad on this forum makes one, no levers . They work good. They advertise in the HOOK.
bm3501466
04-06-2007 05:50:58
 Re: making a locked differential in reply to Earl-IL, 04-05-2007 08:43:41
I think that would be a good idea to make a limited slip differential. I have heard people say they don"t work very well, but I think if you have matching tires it ought to work good especially on a dead weight pull. I would like to know how to build this too without spending 700+ dollars.
Earl_IL
04-06-2007 09:48:55
 Re: making a locked differential in reply to bm3501466, 04-06-2007 05:50:58
Build it between the bull gears on a 2cyl .Others are built off the brake shaft. I haven't built any ,only saw one built on a Moline and he say's he is happy with it.
