v8 conversion
ihman4ever
03-27-2007 22:51:21
i want to build a farmall v8 puller anyone have any info on how to mount engine into tractor
HOT RODDER
04-04-2007 19:28:30
 Re: v8 conversion in reply to ihman4ever, 03-27-2007 22:51:21
I have all the parts you need to put a small block chevy in a M give me a call at 765-969-6125
High Octane
03-30-2007 08:15:36
Does it have to be a V8 to run is a V8 class? Can a 6 cyl be allowed in with the V8's? Just wondering,,
firefarm
03-29-2007 13:26:05
I know where there is a real nice M for sale that has a small block chevy in it. He will sell it complete or I"m sure that you could buy just the chassis. Send me a email or give me a call.
Jason
419-295-6897
[email protected]
This tractor will run 4th gear at 8000 rpms on 18.4 x 38 tires...
Mn dave
03-29-2007 15:58:31
 Re: v8 conversion in reply to firefarm, 03-29-2007 13:26:05
That small block chevy must be putting out some amazing HP or you have a ALOT easier starting and pulling sled than I pull on. Let's see.....8000rpm, 18.4X38 tires...4th gear....40-50mph tire speed??? I know how I have to slip the clutch in 2nd gear @2000 rpm starting off Hmmmmm , unless that chevy is putting out 7-8oohp, it's hard to believe the tractor can pull in 4th gear.
03-29-2007 16:52:08
 Re: v8 conversion in reply to Mn dave, 03-29-2007 15:58:31
700 HP at the crank. Our class limits us to 410 cid, cast iron heads, and 1 750 cfm carb with an 8000 rpm limit. On good tracks, the IH's run 3rd but will run 4th at times. Most come off the line at about 4500-5000 rpms and have a ground speed of around 25 mph.
MN dave
03-29-2007 18:04:28
 Re: v8 conversion in reply to [email protected], 03-29-2007 16:52:08
blowers? NOS? What weight classes? What are you using for clutches? What are you getting for wheel speed? Sounds like fun!!!
firefarm
03-29-2007 18:44:01
 Re: v8 conversion in reply to MN dave, 03-29-2007 18:04:28
all natuarally aspirated, no NOS, and we pull at 5700# and an 18" drawbar. As far as clutches, people are using anything from a single disc clutch from Ft Wayne Clutch, twin disc hays and mcclouds, or twin disc crowers.
Check our website for more information. Rules are under Division 7 Hot Rods.
Tan67
03-28-2007 18:03:58
I know just the guy for you to talk to.Talk back at me sometime
willywonka2
03-30-2007 20:08:47
 Re: v8 conversion in reply to Tan67 , 03-28-2007 18:03:58
Hey Tan67
ihman4ever
03-28-2007 18:30:29
would love the info
MN Dave
03-28-2007 17:42:04
We installed a 440 Chrysler in a M last year. We had to do a little grinding on the side rails but did get engine to fit between rails without stretching rails. We had a steel flywheel built to fit M starter ring (origionall cast won't take high rpms). We used a pressure plate from a Ford diesel pickup and a heavy duty clutch plate from a M (so splines from M tranny input shaft would work).
we have an estimated 435 hp from motor. I pull in second gear, 6000rpm, 18.4X38 cut tires and have been clocked on sled at 14mph. Tractor weighs 4500# with no driver.
I have some video of it pulling, but don't know how/if it can be posted.
big red ffred
03-29-2007 04:34:13
 Re: v8 conversion in reply to MN Dave, 03-28-2007 17:42:04
who made your flywheel ????
Ian Johnsen
03-27-2007 23:11:44
I have a buddy who put a 549 cu in International gas truck v8 into a McCormic W9 and then fully restored it. It took a lot of work. He built an adapter plate to make it bolt up. I believe he had to weld the tractor flywheel starter gear to the truck flywheel. I think he also had to shorten the transmission input shaft, custom throwout bearing.....on and on. I know you're IHman4ever, but you may consider a Massey Harris 55 or 44 for this project. With their divorced clutch housings and chain (or bolted flange) couplers, your options are relatively open. I have built a 55 with a 454 for myself and a 44 with a 400 small block for my buddy.
ihman4ever
03-27-2007 23:16:11
 Re: v8 conversion in reply to Ian Johnsen, 03-27-2007 23:11:44
my intentions are for a farmall m any help there ive been told its pretty easy
willywonka2
03-30-2007 20:15:47
 Re: v8 conversion in reply to ihman4ever, 03-27-2007 23:16:11
looks to me like no one wants to help you man. Chat with tav67 he can help you out with that little project. sounds like fun to me. Shot him an email. Hey tan blow it out
