88 Manifold
EJ
03-27-2007 18:43:19
Looking for the best mainfold and carb set up for a stock 88, 20% over rpm. Not sure if I should look for 880, 1650/55 or ?. Good original or new?
puller 2
03-27-2007 19:40:58
 Re: 88 Manifold in reply to EJ, 03-27-2007 18:43:19
The aftermarket manifolds are repro 1650"s they are a little bigger, and work well. The best carbs are the NOS Zenith"s that are out there. I have some or you can look aroung and find them easily. But if you are running stock cubes an all stock carb and manifold will do the job, think cam ..... ...
EJ
03-28-2007 14:19:23
 Re: 88 Manifold in reply to puller 2, 03-27-2007 19:40:58
Who has or grinds a good cam?
stock
03-27-2007 18:55:11
what is wrong with your manifold ?
Cody
03-27-2007 20:34:22
 Re: 88 Manifold in reply to stock, 03-27-2007 18:55:11
I have found the original 1650 manifolds are a little better than a stock reproduction manifold. With some work the repro can be made alot better. I have a few NOS carbs that will bolt right to the 880-1650 manifolds.
