farmall H max bore
farmall H max b
03-20-2007 03:03:37
Just trying to separate fact from fiction. Can you comfortable bore a farmall H block to 3 3/4? If so, is it with or without sleeves?
LW
03-20-2007 08:11:55
 Re: farmall H max bore in reply to farmall H max bore, 03-20-2007 03:03:37
Just cleaned and inspected(sonic checked) a nice 350 block that I would not go over 3.813 bore in. There was a lot of taper in the casting. This block will be short filled also. I'd say if you don't care about having round cyl. go ahead. Every casting will be different. Some people think .080 is a adequate cyl.wall, In gray cast iron that is nothing!
AC
03-20-2007 04:35:41
That depends. You really have to take a block, bore it and sonic check the cylinders. About any good shop can do this. Its probably a sure bet in a 300 - 350 block, and I have see it in an H block. Only sleeve it if its not thick enough, OR you hit a sand pocket. If you are going to sleeve it, might as well go with a bigger bore, since you gotta bore it and order sleeves anyway.
ChadS
03-20-2007 07:15:10
 Re: farmall H max bore in reply to AC, 03-20-2007 04:35:41
3-3/4, is no problems in a H block. FACT!
