MSD 6AL box
MSD Ignition qu
03-17-2007 09:21:45
How much power/amps does a MSD 6AL box actually send to the coil? is it 6amp and 13.6 volts or is it more than that?
JD hauler
03-17-2007 17:29:07
 Re: MSD 6AL box in reply to MSD Ignition question, 03-17-2007 09:21:45
I am almost sure its a capaciter, a transformer would increase the voltage, and the capaciter would store energy for the multispark, I would think, I wont bet momey on it , just seems right from theory.
MSD
03-18-2007 08:43:13
 Re: MSD 6AL box in reply to JD hauler, 03-17-2007 17:29:07
Do you think a MSD 6AL can run fuel injectors instead of a IGN coil? Wouild it burn up the MSD or the injectors?
JD hauler
03-18-2007 12:07:06
 Re: MSD 6AL box in reply to MSD, 03-18-2007 08:43:13
My guess would be it would smoke both of them, really dont think that would work out.
JD hauler
03-17-2007 10:42:08
My super 88 gets almost 12.5 to 12.8 but the box does draw pretty good on the alternator, but it is a capacitive discharge and muti-spark, so it is really quite efficient when you realize its putting a pretty impressive fire power to the plugs. I think they are a really good system.
MSD
03-17-2007 11:00:02
 Re: MSD 6AL box in reply to JD hauler, 03-17-2007 10:42:08
I have one apart, it looks to have a transformer inside. The MSD isnt creating the spark, its creating the spark pattern, or Multi pulse band. The MSD controls the power to the coil, I can see how or why it would need a stored charge to lite a coil the way it does. A 12 volt coil, no resistor, electronic IGN will produce the same amount of spark, but in a single pulse band instead of 3 or 4 pulses. is it a capasitor or a transformer though???
