another M block question
Charles McNelly
03-16-2007 18:56:41
So, What would be the safest combo for power without having to do alot of work to the block? I would think a 4.25 to a 4.310 bore and a 6.25 stroke. I would like to go as big as possible but only build this motor once. What kind of rpms do most people run these motors at?
Thanks,
Charles
B Barenie
03-17-2007 12:47:48
 Re: another M block question in reply to Charles McNelly III, 03-16-2007 18:56:41
A 6.25 stroker crank has no value in todays pulling world. I would highly recommend not wasting the money ! Depending on the division you want to pull in, a 281 block gives you many options, (depending on club rules).
At 4.25 bore, your pushing aproxxmo 62thds out of the stock cylinder wall, (sleeves removed), at 4.31 wall thickness becomes more critical.
Pushing max bore in any overhaul is every bit as important as stroke, that's where the c-281 block comes in !
a 436ci farmall, with the rite components, will give you many years of competetive pulling (4.375 x 7.25").
If at this time, that's not an option, then stay where your at !
I'm putting together a 370ci motor, and it's not big enough to pull division 3 in my club, and outlawed, where I was going to place it !
Have no regrets about the dollars spent, just have to travel an extra 100 miles to pull !
Hope this helps
Bud Barenie
Charles McNelly III
03-18-2007 12:39:45
 Re: another M block question in reply to B Barenie, 03-17-2007 12:47:48
Thanks Bud, I'm in the process of ordering rims and tires for this tractor. Anybody use the Firestone Superall traction II tires?
High Octane
03-17-2007 14:59:47
So run lightweight modifed. Mafia's SM pulled fine in the light class. Did not run worth a crap, but it pulled good. Motor dont mean squat,, its weight placement. You would be surprized what 100hp would do in the right class and weight. its only more tires, rims, and hitch to get there! Come play with the big dogs!
E85
03-19-2007 22:08:23
 Re: another M block question in reply to High Octane, 03-17-2007 14:59:47
O.K.
What is Mafia ?
High Octane
03-20-2007 07:09:38
 Re: another M block question in reply to E85, 03-19-2007 22:08:23
The Westville Mafia. Any NCIATPA puller tht is on the est side of St rd 39 and northwest of US 30 is in the mafia. LOL!!! I sure hope that doesnt upset em when they hear me say that,,, HAHAHAHA!!! its all in good fun. It means, that all of em run in a group together who live in that area.
Macpuller
03-16-2007 19:36:00
4.25 bore 7 1/8 stroke, you won't have any problems, 115 honest HP at stock RPM. Will run for years.
