Farmall H
Framall H Pulle
03-15-2007 17:12:03
I need a digram to wire an h from scratch with electronic ingtion and altonator. Also what kind of 9 bolt hubs will fit on an H
Thanx
miles
Augie
03-19-2007 12:17:54
 Re: Farmall H in reply to Framall H Puller, 03-15-2007 17:12:03
I've got a set of Z Moline hubs that I might part with.
Ed hodge
03-15-2007 18:44:06
jd 420 hub will fit as well
superh
03-16-2007 21:33:48
 Re: Farmall H in reply to Ed hodge, 03-15-2007 18:44:06
If the tractor has any kind of power the jd420 hub will break. I know from experiance.
Farmall47
03-15-2007 18:00:05
there is a hub from a MM, a Z ithink that will fit. Also Oliver 77, but you have to have the key machined that is part of the casting. The MM need keys made. The MM are the better choice I think. AJB
