301 IN A M FRAME
LIVIN LUCKY
03-15-2007 14:08:49
I GOT FOUR 301 MOTORS WANT TO TRY PUTTING ONE IN A M FRAME . GOT THE RAILS FOR IT
ChadS
03-15-2007 18:15:03
 Re: 301 IN A M FRAME in reply to LIVIN LUCKY, 03-15-2007 14:08:49
Bolt it in there! 560 rear engine plate, 560 rails, 560 flywheel,pressure plate and a SM clutch disk. You may have to put a M starter ring on the 560 flywheel, or get a 3 bolt starter bellhousing for a late SM and possibly use a stock 560 starter with no starter ring alterations. if you have the rails your in good shape, you may want the tractor timing cover to make it all match up perfectly.
